Will Be removing my wheels to paint the callipers...Read in the MX5 handbook the wheel nuts need to be 88-118 N.m
Does this mean anything in between is ok ?
Learning as I go
Cheers
The most useful torque wrench for general use will be a 3/8". but you should also have a 1/2" for heavier work like wheel bearings. 1/4" is a bit of a luxury in most tool boxes but would be useful for a beginner who has not yet worked out by feel how tight to do up light screws and fastenings.
Most Torque wrenches will have a dual scale, Nm and FtLb.
Make sure that the different scales are clearly legible and identifiable. (They aren't always) you do not want to accidentally mix them up when setting the "Click" point. That would be Bad....
As for the question..
We have the potential to end up in much can-of-worms territory. Torque refers to twisting force. but this can be affected by many different things. In an idealised scenario, it is directly related to the amount of stretch applied to the bolt in elastic deformation which in turn relates directly to the clamping force applied to the component.
In practice, the condition of the screw thread, presence of dirt and corrosion, the accuracy with which the threads have been machined, the condition of the bolt/nut faces/washers and the condition of the faces of the components being bolted will all affect the amount of friction in the system will all affect the amount of twisting force needed to produce the correct amount of stretch.
(And this is before we go into the controversy regarding the use of lubricants)
In an ideal world, all nuts/bolts should be cleaned up with taps/dies degreaser and an airline before use. and all tightening should be carried out using angle torquing (Which defines precisely just how much stretch is applied to the bolts/studs)
A torque wrench is basically a quick and dirty short cut, and because of the issues mentioned, a series of apparently identical bolts might well end up with widely different amounts of stretch despite having identical amounts of torque applied depending on their condition and the presence of lubricants
This being the case, the precision of the calibration is not as relevant as you might think (Within reason) what is rather more important is the consistency. (Does it always "Click" at the same torque time after time)
It is also important to ensure that everything is thoroughly cleaned before reassembly. and, while few people do this in practice, a set of taps/dies to ensure everyting is
really clean is recommended in an ideal world.
Most torque settings are for "Dry" fasteners (ie no lubricant) Using lubricant can increase the amount of stretch by 30% or more for the same torque applied. Of course, use of lubricant has no effect on the stretch generated by angle torquing.
