Hiya. Glad I found Overclockers as I was really having trouble finding a company that built quality PCs in the UK. Anyway, I'm here now.
Can I have some advice please?
I'm looking for a quality component PC, not for gaming, but for trading.
The main role of the machine will be to run 6 AOC 34" widescreen monitors running at 3440x1440 (21:9 aspect) (this is the model
Here are my comments on the following -
Speed: Not such of an issue. I think i5 (or similar AMD) will be fine. The programs I use are small and generally slick. I won't be running much in the background either, or at least nothing that's hungry for lots of power/speed.
Graphics capabilities: All I'll be having on my screen will be 18 charts, they will update every second but nothing moves fast like games.
Graphics cards: As I mentioned, 6 34" wide screen running at 3440x1440. I was therefore looking at the Nvidia Quadro 1200 offering 4 mini-display ports. Any comments on that card or alternatives?
RAM: My system at present is 8GB and it's sort of enough but I want to go 16GB just to be safe.
HD: 500GB Samsumg SSD
Secondary HD: Not needed at present, I can always add one later if need be.
Noise: Needs to be generally quiet.
Ventilation/heat: The machine will be under my desk and there's not too much airflow. Plus, the office is generally warm.
Case: Nothing flashy needed.
Reliability: Needs to be rock solid and it will be on 24 hours a day, sometimes for weeks (assuming no software reboots are needed).
Future expansion: Not really that important. I'll probably use the machine for 5 years then replace it with a whole new system. And the software I'll be using won't need the latest and greatest spec to run effectively in the future either.
Budget: £1,000 - £1500 incl. VAT. One of the main costs I think is going to be the graphics cards.
Keyboard/mouse etc: I have everything so only the system is needed.
Ports: Nothing special, standard USBs (4-6) and USB3s (1-2), network etc.
Any advice would be really appreciated. I'm not in the market right now but will be in around 2-3 months. At present I'm just getting a feel for things and prices etc. Thanks.
That being said I think I've been upstaged by Armageus 2 x AMD FirePro W4100 is only £270
