Spec Me a Traffic Monitor
8 Jun 2013
Is there such a thing that will give you a simple readable/understandable breakdown of what's using your bandwidth? i know Win10 has the resource monitor thing but i couldn't really make sense of what it's showing me ~ loads of SVCHOST things that didn't make anything clearer, eg.
TIA
I was going to say Google Maps but that wasn't right.
I'd be interested in something that analyses data traffic, not sure how complicated it might be though.
Andi.
Grafana is very good for this depending on how granular you want to be.
Cacti is also another one which id look at.
Process Explorer is pretty good for a live monitor.
Svchost is windows services, likely Windows update.
Ubiquiti Unifi USG to replace your main router? Has pretty good DPI and will break down per device.
i've got one of those and it's great for telling you what device is bandwidth consuming and what type of data it is, but i've not yet found out if it will break it down further.
What it did tell me is one of the comupters in the house has uploaded 5GB of http traffic in about 6 weeks, so it's narrowed down my search a lot. Will hit that PC with one of the above tools tomorrow and see what it reports. Thinking Glasswire or Netlimiter at the moment...
