Spec me a triple monitor set up please
25 Jun 2015
Leicester
Looking to buy 3 monitors mainly to use with driving sims like iracing and assetto corsa, but have absolutely no idea which monitors to buy.
The mount i have ordered will take 3x 27" monitors and ideally i would like the thinest bezels possible to minimise the black bars between screens.
They will be ran from a 980gtx 4gb which i cant see myself upgrading anytime in the near future. As for budget ideally between £200-£300 per monitor but the best bang for buck is what im after i dont want to buy the most expensive monitors in budget if they have features i can't use with my current system spec (see sig).
thanks
For thin bezels you can't go too far wrong with the current range of Dell U series monitors - almost non existent. I got the 27" recently and can recommend it but it's likely out of your price range. Maybe the 24 or 25 is in budget?
