I am looking to purchase a decent trolley jack that is capable of lifting my MK5 Golf GTi (Kerb Weight 1650 Kg) and some decent axle stands that let me work under the car safely.
My budget is flexible but under £100 would be ideal.
EDIT - I should just add that its just for infrequent use. At the moment I want to replace my DV valve under the engine, but in the future will probably just use it when servicing the car or taking a wheel off.
