Meh,.
Only had this computer less than a month and already seeing it is struggling. (spec in sig) I have around £100 to play with what would you guys recommend?
It's struggling because you are trying to make it do more than it physically can. Did you spec the machine for the purposes of playing those games? Did you use their recommended specs as a guideline?
Throwing £100 at it isn't going to give you an adequate performance increase in those games that will make you feel it's no longer struggling.
you would have to sell some old parts in able to get something semi decent....
even then i doubt you getting much money to make mass improvements at all....
personally i think you would get £100 max for ur gpu... giving you £200 for a new card maybe but unlikely.. even then i would spend at least £230 £250 on new card at least
same with cpu... i think you need to save a few more coins up
