Spec me a upgrade.
29 Dec 2012
Spec me a upgrade.
I'm think Ryzen would be the best option but I cant figure out what motherboard or Ram To get.
I also want the option to be able to upgrade next year when the zen2 comes out.
My current specs;
CPU - FX 8320 [email protected]
GPU - MSI 280x
RAM - 8GB Corsair Dominator DDR3
Mobo - Asus Sabertooth 990fx
Custom Water Loop on CPU only,
Samsung 850 evo 250gb, 1Tb Seagate
XFX Black 850w PSU
Phanteks Primo ( A little big)
30 inc Samsung SyncMaster 305T
I use the PC for General PC use, Gaming, Streaming, some one off editing, image editing video editing and creating.
If you mean Twitch streaming then either the R5 1600 or R5 1700 depending on your budget will be good for that as well as editing etc.
You can go with a B350 board if you don't need SLI support. Something like the Gigabyte Gaming 3. As for Ram I would look at 16GB 3000MHz or above.
