Spec me a USB WiFi adapter
10 Apr 2008
I've just moved some stuff around in my flat and now my PC is far away from my VM Superhub so I've been forced to use a crumby old Belkin WiFi adapter that can only detect 2G and is always playing up anyway.
I was hoping to find something that will allow me to make the most of my VM 100mb connection and which would be good for online gaming as well, but there's a lot of different options which I don't really understand. E.g., Wireless-N, N+ and AC+.
Do I want something along these lines:
https://www.overclockers.co.uk/showproduct.php?prodid=NW-121-TP&groupid=46&catid=1600&subcat=2864
Or should I shell out for one of the more expensive Asus ones:
https://www.overclockers.co.uk/showproduct.php?prodid=NW-086-AS&groupid=46&catid=1600&subcat=2864
Edit: btw, I had thought about getting a PCI wireless card but I'm using an mATX board and the only space PCI slot has a sound card in it so that's not really an option.
I was in a similar situation as you and went ahead with the TP Link. It's very good and I get the full speed out of my 50mb VM fibre (get the same download speeds when connected wired and wireless).
