Spec me a USB wireless adapter
20 Nov 2009
Hey guys I'm after a decent dual band wireless adapter for my PC.
I was looking at the Linksys AC1200 but not sure if this is up to the job?
It's for a desktop PC upstairs and the hub is downstairs.
Any suggestions please?
ALFA adapters are some of the best USB based adapters but they are generally more expensive (the AWUS036ACH is like £40+). If you want to cheap out (<£15) then any old thing will do as they're all based on the same cheap Realtek or Ralink chipsets. Get one that allows a detachable antenna and avoid the nasty thumb sized ones.
