Spec me a vertical mouse for my nephew for gaming
1 Apr 2014
Aberdeen
It's my nephew's birthday coming up. I don't want him to have the trouble I had. He's already mentioned having aches if he doesn't use a wrist rest. He doesn't want to use a trackball (as I do). As it's for gaming he'd probably prefer a wired mouse.
He's right-handed.
The mx vertical is probably the best spec of them so far but the Lift might be able to give you reduced weight if you use AAA batteries instead of AA. Just use a little ball of foil in the space and you drop from 25g to 12g or even 8 if you use slightly more expensive lithium batteries. I've ran my g305 that way on the laptop for years with no issues. A little less weight might make it easier on your wrist? Could also use a faster pad. Shame there's no higher end 3370 sensor or above yet. Maybe they'll do a gaming version in the future
