Spec me a vesa mount
Caporegime
24 Oct 2012
Yer nan's knickers
Hello folks,
I need a VESA mount for my glass desk, so it needs to be a clamp type rather than a screw-in (happy to reinforce the glass with some wood if necessary). It needs to be able to support a 32" monitor (quite a chonker) and one other monitor which is yet to be determined.
The end-game is to free up desk space as I'm starting my studies soon, but I don't want something that's going to get all floppy after a few weeks / months.
Any suggestions?
Cheers :)
What's the weight of the monitor as that will determine what monitor arm you need?
I used an Ergotron monitor arm on my 10Kg + ultrawide and it is built like a tank, top quality I would say and not likely to sag or sink.
Hi, thanks for responding. I ended up getting a cheapo Elived jobbie as I had some credit on that other place they have now, so far so good. Not bad for £20, even if I say so myself :D
Once we buy a house I'll likely be looking at things like Ergotron as I'm not sure what desk I'll be using yet.
