Spec me a waffle maker?
13 Oct 2008
SE London Born and Bred
I want to make fresh waffles but not sure on what waffle maker to get.
Anyone got one they want to recommend, looking around Andrew James ones seem okay for about £25.
The cuisinart wafu model ones are good, I had one off of ebay
They have removable plates which is a big advantage for cleaning, just immerse them.
New they are nearer £50 though from JL, I think
You can make a batch, keep some in fridge and then put into the toaster.
The makers are a bit bulky though for storage, and often I just make (thick) American pancakes in a frying pan with same batter - with costco maple syrup.
I got a cast iron one for the stove from Selfridges.
It is tricky to use because you have to control the heat manually but it makes amazing waffles.
I guess that is ice-cream ? not the white butter you get in pancake restaurants in the USA ?
the butter they give there in hemispherical scoops melts in the pancakes/waffles much better than regular pat butter in the UK and one day I need to find out how to reproduce it.
I have only made batter using either baking powder or mixed in egg-whites to raise it, but a DinnersDrive-inDives last week, supposedly with genuine Belgian waffles, was using yeast for raising
That's Greek yogurt in the photo I think in this instance.
This is what I have.
https://www.amazon.co.uk/Nordicware-Aluminum-Stovetop-Belgium-Waffler/dp/B00004W4UE
