Spec me a wall bracket
Mp4
Mp4
21 Apr 2006
Eastbourne
Hi all,
I'm after a TV wall bracket (50" 43KG) as i'm moving the TV to my GF's house.
My current bracket is totally meh. its a flat wall bracket and doesn't give me any movment to tilt up or down which is quite annoying as sockets are located on the back (power etc) IT was quite hard to get into place only thing i can do is move from left to right.
I dont want to make this mistake again!
£80 limit or cheaper the better :)
most tilt brackets follow a very similar design. Just make sure it's rated to hold the weight.
TBH, I think any sort of recommendation is going to be followed by dozens posts saying something cheaper will work just as well until the bottom of the barrel is well and truly scraped. Just have a Google :)
Thanks for advice!
Further searching i found one from amazon £17 jobby which can tilt 15 -/+ :)
If it the one i think your looking at then that does the job, i have had two plasma's hanging on it, one really old heavy panny and a new lighter panny, takes the weight no probs.
