Spec me a wall mount
Permabanned
21 Nov 2010
Newton Aycliffe
Hey guys, looking to get a wall mount so i can fit a 3rd ProLite E2407HDS 24".
Needs to be able to angle downwards so i can see the panel properly as its TN, any other angle is a bonus but not required.
There isnt a huge amount of room between the wall and myself so it cant stick out too much either.
I have had a look and they all seem to be pretty much the same, but the ones that angle are expensive as hell or stick out loads.
Any suggestions appreciated :)
Is it one like this that your looking for
Masterplug Ross Neo LNST200-RO Swivel and Tilt Wall Mount Bracket for 23-37 inch LCD, LED, Monitor and TV Black
Price: £19.18
Product Features and Technical Details
•Swivel and Tilt for perfect TV viewing
•Easy slide on installation and Safety locking screw
•Quick release for easy tilt adjustment and elegant wall mount cover
•Neo’ pads for TV protection and improved audio
•Spirit level for level installation
Technical Details
Designed for 23 - 37" TV's
Locking Tilt clip
Integral spirit level
Protective soft feel pads
Max weight - 25kg VESA 75x75 100x100 200x200
Full Fixing Kit Included
