Hi Folks,
I currently have the following spec
E8400 @ 4ghz cooled by a Noctua NH-U12P with 2 fans on it.
4870 512mb with an accellero and a 120mm fan on it.
2 case fans.
I am thinking of trying my hand at a water cooling set up. I think just for the moment I'd just cool the cpu with it altough cooling the gfx card is tempting. I'd also be looking for a new case too as my current one is really battered. My ideal set up would be very quiet with a similar cooling potential as I already have.
I have specced the following for the build.
I haven't added the barbs and pipes I was hoping someone could suggest some.
I don't have loads in my case, only a dvd-rw and 2 hard drives.
Question is could I add a gfx cooler to this loop?
Is the case good for water cooling? I don't want to do any cutting of the case so the rad might have to go outside, what do I need to do this?
Is there a better case for the job? I'd ideally like a window but really it must be small and quiet.
Thanks
Matt
2 case fans.
Thanks
Matt
