- 26 Dec 2013
- 404 Not Found
I am currently in the process of a new build with a Bitfenix Prodigy ITX. I have some basic knowledge about water cooling loops but the only experience I have with using them is my H100i.
I am looking to have a CPU and GPU block. The CPU will most likely be my existing i5 4670K @4.2 GHz, not 100% sure on the card yet, but i'm thinking something along the lines of a GeForce GTX 970, unless somebody recommends something better (not sure on their running temps).
The prodigy has been gutted of all hard drive trays and 5.25" bays.
Here are my questions:
1 - Can you fit 2 x 240mm rads in a prodigy?
2 - Could I get away with just 1 x 240mm top mounted rad to cool both CPU and GPU?
3 - Would I be best just to have a water cooled loop for the CPU and leave the GPU air cooled, and use a card with a rear exhausting air cooler?
4 - I prefer the look of rigid tubing rather than hoses. Is it fairly straight forward using rigid tubing, or am I better off going with the hoses to begin with?
Any suggestions and ideas for this build is appreciated.
