spec me a water cooling setup!
1 Jul 2007
Am new to the water cooling thing so not sure if i should buy a kit or buy parts and do a macguyver....:rolleyes:
Not sure on a price range so spec away and i will see how many pennys i get from the back of me sofa.
Oo nearly forgot am only looking to cool a phenom II 955 to start we but would like some scope to overclock maybe to 4ghz or so if its doable. If u need anymore info off me ask here or place ur fingers on ur temples, close ur eyes and think of nekkid sexy redheads and i am more than likely to appear:p
thanks in advance:)
(i know my sig does no match setup but thats coz i r in the building buyin phase)
What research have you done so far? We can answer specific questions, but 'spec me' is fairly inappropriate for water cooling. It's quite important that its matched to your system, but more important that you're familiar with the ideas behind it.
Generic spec is liang ddc + whatever radiators you can fit in your case (which case? external?) + ek blocks
