Spec me a Water cooling system...
6 Oct 2007
Liverpool
am not being lazy... am just not sure which is good nor bad.
I need to do sum reading before i do this but i am upgrading to water cooled as i am going to be clocking my CPU.
so any recommendations off a decent kit at a decent price...oviously willing to buy parts separate. ??
cheers
That siberian tiger kit (for what it is) is no more modular than a aircooled heatsink. If you ever want to upgrade or add GPU into the loop you can't.
Most people on here would recommend nothing less than THIS
or maybe google for "Extreme CPU Watercooling kit (PA120.2)" for more performance.
buy expensive, buy once: buy cheap, buy twice.
1 x Swiftech Apogee GT Extreme Performance CPU waterblock
1 x Black Ice GT Stealth I
1 x D-Tek dB-1 Compact 12v Pump - Ultra Quiet
1 x Swiftech MCRES-Micro
6 x Masterkleer 7/16" ID (5/8" OD) PVC Tubing
8 x 12mm Hoseclip
1 x G11 Coolant (Corrosion Inhibitor) 50ml
1 x YATE LOON 120mm - D12SL-12
you can get al this in a kit for 120 quid (elsewhere tho)
That is the kit i am going for when i upgrade to Water Cooling later this month but am going to switch to a D-Tek Fuzion block
Should lower me temps somewhat!
I concure, get as big radiator as you can, and even if you have to get a 120.1 or 120.2 the go for the Thermochill PA. The Black Ice GT Stealth is not brilliant, it's the only advantage is its slimline size. I got it a few years ago and it's just OK but i'm getting a PA 120.3 now as i've added more blocks to my loop and need something more powerful.
8 x 12mm Hoseclip
Swap the Apogee for a D-tek Fuzion (you'll need it for a Q6600) and the rad for a 240mm (120.2) one. The GT Stealth is a bit thin, so either a Swiftech MCR220 or a Thermochill PA120.2.
Got one of those kits today that F1ZZY linked to
Easy to install and my temps are nice n low again (just used the 12v to 7v leads and now she's silent and not really any change in temps)
You could get that kit and then at a later date add to it i guess (as said if you're gonna be cooling every chip move up to larger rad)
Good for the money, Easy to install, And it works
Mines in a lian-li PC-G70 so loadsa room and rads sat nice on the rear :)
I had hunted around for parts to make my own kit up but with deliveries from allover the place and bits out of stock i went for that kit as it's less hastle
No doubt you'll be thrilled with the temps whatever you decide
Ciao
Def
