- 7 Aug 2004
As title, I currently use a 4930k with a Corsair H100i which is great to be honest, temps are around 60-65 load at 4.6ghz
But I am now using 2x AMD 290x in crossfire which as you can imagine is getting mighty hot - one is a reference card with Raijintek Morpheus on and the other I just got is the Asus Direct CU II OC.
However the gap between the cards is really small and having airflow issues now with the two cards with the Morpheus on top reaching 93c in gaming, the Asus gets to around 80c.
I use a cooler master Haf X case with an MSI Big Bang II Mainboard.
I am a competent computer builder and have done so for 26 years.....but never properly ventured in to water cooling but I am sure I can put it together well........I just don't know much about the parts.
I would like (if its enough) the biggest possible rad in the top, and perhaps a 120/140mm rad on the back of the case pushing air out............and all the other stuff if you could spec me...........would be awesome, with info on what you would want to do
Many Thanks
EDIT: Would also like it to be as quiet as poss (whatever the best high pressure quiet fans are?)
Money isn't really an issue but I Don't want to pay 300% more for 5% increase if that makes sense, a sensible water cooling setup that lets me overclock the CPU & GPU's
Many Thanks
