- 14 Jan 2013
Been browsing ocuk for water cooling parts for my current build
Gigabyte z390 pro wifi
9700k
Gigabyte aorus 2080 super(soon)
Lian Li 011 air
I REALLY like the look of the heat killer stuff + the 150 aquacomputer pump with the digital readout.
Would be going for a stealth black/white/chrome build, does the white hard tubing degrade or the dye from it seep into the water over time though?
It would either be white tubing, or clear + blue dye coolant as I think that would set off quite nicely against the black and white.
What other parts would you recommend, as this is my first foray into a custom loop I could use all the help and advice I can get, been watching jayztwocents for years now and I think I am ready to take the plunge.
9700k
Lian Li 011 air
