Spec Me A Watercooled PC!!!
6 May 2010
Nottingham, UK
Hi Guys,
I have never built a Watercooled Pc but have done some reading on it and would
like a nice watercooled PC for Gaming with.
Could you guys maybe spec me a watercooled PC for gaming.
With a Limit of about £12-1300 to spend.
Thanks
Well first of all we need to know what the computer will be used for computer for and are you water cooling for silence or performance?
although the h50 is technically watercooling it gives nowhere near as much satisfaction as finishing the proper job yourself. what you should do is build a rig on air clock to your desired speeds and then if your machine is too hot find out what is too hot then look into water. dont waste money you dont need to
I would be using the Computer for gaming.
And i would prefer to watercool it for performance, but for it to be a silent as possable
would be nice but not essential.
I would also like an i7 Rig if possable.
do you have a separate budget for the 3 monitors or is everything included in 1.2k-1.3k budget?
it might be hard to squeeze an i7,custom watercooling kit and 3 monitors..hmmmm
The monitors is gonna come out of a seperate budget.
So the 1.2k-1.3k is just for the watercooled system and then i will get the monitors after.
No one has actually specced him yet :P
I'll have a go.
There is no reservoirs in stock,and figure out how many fittings you'll need :P and how much tubing you will need. You could also swap the tubing for some coloured tubing.
If you want a different GPU as I see there is a bit of discussion whether to go AMD or Nvidia, you will need to change the waterblock.
