Would really appreciate any help on this lads, I’m in a bit of a quandary. I need a case for my new loop, but I’m restricted on space and I don’t want anything with very restricted air flow, which seems quite common at the minute. Budget is about £150.
Case will spend a lot of time running in a cupboard, but not always. The cupboard is fitted with a 420mm intake, and sufficient exhaust. The issue is the length restriction, case needs to be less than 470mm long!
Requirements below:
As I said any help is really appreciated lads, I keep coming across cases that I think are ‘the one’ but then it seems to always fail on at least one of my requirements.
Requirements below:
- Max Length (Front to Back) : 470mm
- Max Width : 260mm
- Max Height : 580mm
- Colour : White, black accents preferred
- ATX Mobo support
- Radiator support : 360mm + 240mm
- Drives : 3x 2.5” min. One of these is 15mm!
- TG Sidepanel
- Front intake, that’s not too restrictive
- Decent cable management
- Fit Corsair Commander in cable area
bottom-top airflow
