Street said:CPU Block: D-Tek Fuzion
Pump: Laing DDC Ultra with Petras Tech top
Res: Swiftech Micro Res
Rad: Thermochill PA120.2
Tubes: Tygon 1/2"
I wouldn't bother with a NB block personally. You can get mounting kits to mount the rad to the back of the case, the rest should fit inside, either that or you can mod your case to fit the rad inside!![]()
