Spec me a watercooling setup?
2 Sep 2010
Somerset
Hey guys,
I am getting bored of high noise just to keep my system cool with my h50. When i put my fans on silent, they reach around £45*c.
Now, I have £300 max to spend on a watercooling setup. The reason being is because i usually leave my system on for F@H and a lot of the time, rendering video( my 965 @ 3.8GHz is fine for what i render :) ) My case is a CM 690 II so a 240mm rad would be the maximum it can fit.
So, im looking for basically everything the get the system watercooled. I know overclockers don't sell a lot of water cooling parts so if you could give me the product name, I will find it my self :p
BTW, I only want to watercool the CPU, not the GPU.
Cheers all :D
-EK supreme HF
-Swiftech MCR 220
-Swiftech micro res
-Swiftech MCP35X (PWM speed controlled version of the 18W DDC with an after market top pre fitted)
-6 1/2" barbs
-Hose clamps
-4m XSPC hose
-2 scythe GTs
-Silver coil
-Some deionised water
Can be found for £250~ total.
If you wanted you could also fork out for a fan controller so you have more control over fan noise etc.
