Hi guys, thinking of going underwater in the summer, but have little knowledge of the best components. This is hopefully where you come in
Going to be cooling sandybridge, probably an i7 2600k @5ghz, with 2 580's which I will probably overclock. I have decided on a dual loop setup, with one 120.3 rad and one 120.2 rad (going to be modding the phantom to accomodate these
) with the cpu on one loop and the 2 gfx cards on the other. I have already decided on the reservoir: http://www.xspc.biz/ddcdualbayrestwo.php, now I just need to decide on the rest of the parts
I will probably be using dyed fluid, with plexi blocks and Blue LED Silverstone AP121 fans, so I just need to know the best tubing, pumps, radiator and blocks for the job, as well as the best fluid, dye and thermal paste. A good fan controller is also a must. Cheers guys, and I will mention you in the project log over the summer
.I will probably be using dyed fluid, with plexi blocks and Blue LED Silverstone AP121 fans, so I just need to know the best tubing, pumps, radiator and blocks for the job, as well as the best fluid, dye and thermal paste. A good fan controller is also a must. Cheers guys, and I will mention you in the project log over the summer
