Spec me a watercooling system
7 Dec 2008
UK
Posted this in the Overclocking and cooling section but diddnt get a response so here goes again... i need to cool an HD 4850 and a core 2 duo (LGA775) i would like a resevoir in the drive bays unless its not a good thing.... just looks good my case is lit by blue LEDs so any UV reactive liquid in blue or green should look good, i have a window so it would be nice if it looked nice aswell, i spent ages with cable management and wouldnt want it to be wasted, i think i have 2 spare bays (am not at home atm) so unless the res was single bay i would need a fan controller somewhere else, can you get 3.5" bay controllers? i dont really have a budget but dont want to go spending too much, so lets say under £350? but the less the better! thanks guys
Try doing a bit of research yourself on the net and use the search tool on here and search 'watercooling'
People really dont appreciate 'spec me' and no effort from the op going into it.
that is most likely why you haven't had any replies.
^ A bit harsh flare mate.
I would spec you something, but I know little about watercooling.
Hopefully someone else will help you out. :)
Flare thats the whole point of the forum. to help people get the best they can for what they need, when they themselves have little knowledge of the subject.
