Spec me a wc set up
8 Sep 2012
I have been doing a fair bit with my pc lately and tbh I am finding the fans on my 680's very loud on max chat!
So it got me thinking about WC.
I would be extremely grateful if one of you kind people could spec me a WC set-up. Here is my spec-
NZXT Switch 810 case
i5 3570k cpu
EVGA gtx 680 superclocked signature 2 x2 gpu's
Also I only have a single dvd drive so if the xspc front bay res/pump is a good choice then I believe it will fit fine.
I also considered getting this then adding gpu blocks and anything else I would need for it on?
YOUR BASKET
1 x OcUK Tech Lab - V8 Watercooling Kit 240 £120.41
- 1 x Mayhems Ultra Pure H20 Watercooling Fluid 1L £4.99
- 1 x XSPC RayStorm CPU WaterBlock (Intel) £49.98
Total : £186.78 (includes shipping : £9.50).
Any help is most appreciated
Regards
Nick
120 of raddage per component
I'd buy the kit, 2 more fittings and a 240 rad. One on top, one in the bottom.
Personally, I'd go for a better pump like a D5 as I think it's worth the investment. The current pump should be fine in your loop, but a D5 will 100% be ok as your loop will be relatively high restriction.
YOUR BASKET
1 x XSPC RayStorm D5 RX240 WaterCooling Kit ** WITH FREE WOW EXPANSION ** £264.98
2 x XSPC Razor GTX680 GPU Waterblock (Raystorm Style) £89.98 (£179.96)
1 x Hardware Labs Black ICE Radiator SR1 240 £55.98
2 x Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin £13.99 (£27.98)
6 x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) £2.99 (£17.94)
1 x XSPC 7/16" ID [16/11mm] High Flex Hose - Clear [1m Length] £2.99
Total : £561.82 (includes shipping : £10.00).
As for fluid, get some cheap DI from halfords :)
as above, spend more now and save later....watercooling don't come cheap, my loop was nearly £620
it is the business though ;)
Sweet thanks for the spec! It's pretty much probably a extra 200 on top of what I thought I could get away with but I would rather do it properly if I'm to do it do il wait a bit and go for something like this!
