Spec me a wifi set up
18 Oct 2002
Hi
I've just for fibre installed. Love the speed wire connection the best. But can't really do that here. I rather have it all wireless as iPad iPhones and laptops in several rooms.
So I want to get a strong wifi set up done I believe duel band way to go but which fibre router with modem should I go for. Or can have router and plug it into open reach modem they installed.
Will also like a wifi extender
Pls specs what I should go for brand and model pls
I still use the plusnet router (with the wifi off) and a Ubiquiti Unifi long range access point. That comfortably covers my whole house and gives wifi speeds of 47Mbps down and 16Mbps up (on wired I get 74/18Mbps). 2.4ghz N is fine for me and it has very good range and stability compared to other AP's I have used. If I had more devices that could take advantage I would probably get a the pro or the AC version but for the extra cost and the fact that I don't really need it means it's not worth it at the moment.
Dave
