It all depends on the distance from your router if your on dektop, theres no point in having a rangemax card if your only 5-15 metres away, also, if you buy a wireless N card, 802.11N, make sure your router is capable of this as well, or you wont have any benefits, as it will run in G or B mode.
Hope this helps a little, if you need help finding whether your router supports N, tell us what type it is
