Spec me a wireless keyboard with a touch pad please.
Permabanned
26 Jul 2007
Coventry
Would like it so that I can use the keyboard with my desktop PC whilst lying in bed. The Computer will be about 4m away from the bed, but I have a 22" (soon to be 28") monitor.
Anyway I've only seen four really, just wanted to know if anybody can recoment any others, or knows anything about the below?
http://www.overclockers.co.uk/showp...ame=Logitech diNovo Mini Keyboard (920-000586)
http://www.overclockers.co.uk/showp...me=Logitech diNovo Edge - Retail (967685-0120)
Those two are both too expensive.
http://www.overclockers.co.uk/showp...K-612RF Black Wireless Keyboard with TouchPad
http://www.overclockers.co.uk/showp...Keysonic Wireless Keyboard/Touchpad ACK-540RF
Those two look great, but I'd prefer something with a numpad perhaps, or at the very least rechargeble so I didn't have to keep swapping out batteries every few months.
I don't mind if the keyboard is bigger than any of the above if it has a touch pad or an IBM style "nipple", I'm not particularly after a compact 'board.
The only other keyboard with touchpad worth looking at other than the Dinovo Edge and the two Keysonic offerings is another Logitech keyboard called the Logitech MediaBoard designed for use with the PS3. Decent keyboard, a bit plasticy and no numberpad but it works and is a fullsize keyboard.
To my knowledge there isnt any rechargable wireless keyboard with track other than the dinovo edge. Just wish I had the money for one :)
Cheers for the input (geddit?:D),
that media board looks very nice, I take it works perfectly well with a normal PC as well though?
just done some research on the MediaBoard and it seems to have some issues with working on a PC, touchpad won't work all the time etc... and no windows key, and media controls not working. Which is a shame because it looks rather sexy.
Basically I would like a wireless keyboard, with a touchpad, media controls (or at least volume controls), and be rechargable. And it'd be a bonus if it had a numpad, was backlit, or looked sexy.
Basically I'd like a cheap DiNovo Edge
I'm not sure, only coz I dont think you can use a ps/2 and usb keyboard at the same time. There isnt a cheaper version of the dinovo edge, otherwise I would be using it now :D
