Spec me a wireless router?
18 Dec 2008
Liverpool
Currently on Virgins Home Hub for 200mb Fibre but I've heard you can put it into modem mode and use a 3rd party router... I'm looking for something that can handle my online gaming while the kids watch Netflix and the missus is on Youtube etc. I also want something I can install a VPN on so I'm not having to install them on each device individually and that has a stronger signal in certain parts of the house that can drop out using the Virgin router. Ideally it will allow me to have both wired (gigabit) and wireless connections.
What do you guys recommend?
Ubiquiti Edgerouter 4 with a UniFi UAP Nano HD wireless access point and throw in a gigabit switch. That'd tick every box and be extremely uncompromising on performance.
Will it be a pretty 1 box solution? No.
Will it be a breeze to set up? No.
Is it going to cost less than £100> No.
It does meet every criteria given and have room for growth though.
Quite a bit more than I was looking to spend but thank you, its good to have an idea at what I'll be looking at to meet my needs.
