Spec me a wireless speaker!
19 Sep 2010
The North
I've recently moved into a flat, and want to sort out a wireless audio system for me and my girlfriend to use.
As its a flat, it doesn't need to be anything particularly powerful, but sound quality is still the priority!
Spotify Connect would be highly, highly preferred, as would AirPlay compatibility (although I suspect this is less of an issue with systems like Sonos, with their own excellent apps)
£300 or so would be my top end budget
Thanks in advance
I am really interested to know this as well. I want to be able to stream from Spotify on iPad to a small speaker.
I have asked before but have never had an answer. I find audio stuff a little confusing.
Well the Bose Soundtouch 20 sounds decent enough, but I've heard there's typically always a better option than Bose at any given price point!
Depends what your budget is - I've posted in another thread but Muzo Cobblestones do the multiroom and work with spotify connect
http://www.muzohifi.com/
They're badged as DigiFunk® - WiFi Wireless Audio Music AirPlay Receiver 3 on amazon. Currently £39.99 but you need a speaker as well. I currently have 2 and getting a third.
I think the exception is the mini sound link. It's amazing when positioned well. Have mine hooked up to an old apple airport express for AirPlay when it's in it's home, or I can Bluetooth and carry it to a different room :)
Not perfect for your requirements though, still worth a look/listen.
Nox
