spec me a workstation.
233
233
21 Nov 2004
Wishaw
is it possible to build a better workstation that what i've specced below for the same or close money?
all work and no play so will be used for office apps our dispatch software which is browser based and a couple of communication apps only requirement is a need for a good chunk of screen real estate. happy with larger dual monitors but could be tempted with a triple setup if the bezels are thin enough.
so far i have
LG32 QN600 x2 £440
Mac Mini M1 256gb. £699
Total £1139
anyone care to spec up a pc equivilant for under say £1300?
Micro atx build .
5600g 6 core can do dual 1440p with 500gb m2 drive 16gb of memory and motherboard has hdmi and do port, woth Wi-Fi.
5700g is 8 core but adds £50.
Please check to concur all recommendations.
Windows keys can be had for £10.
CODE My basket at Overclockers UK:
Total: £491.04 (includes shipping: £11.10)
cheers Micky, didnt realise the apu was capable of driving multiple displays, every day is indeed a school day
If it's for a business, I wouldn't recommend using the 'windows keys for £10'. Should your business become subject to a licensing audit, those £10 keys will be very diffifult to justify as most of them are OEM issued to the likes of Dell, HP, etc (if not, MSDN keys).
