Spec me an ATX Case
18 Nov 2011
Kent
Evening all.
I have just taken delivery of my HIS 7950 and it is bigger than I thought, or at least my current case is smaller than I though! It would not fit without some serious bodging so I need a new case.
My budget is only £50-60 as I already destroyed the budget getting the 7950!
I am not too fussed about aesthetics, just something that the HIS 7950 will fit in comfortably.
Thank you
Well I upped the budget a tad and got the HAF 912 advanced, mainly due to the removable hdd cage giving you looooads of room for a GPU.
Really happy with it, nice and quiet with good pre installed fans. Really heavy though so not reccomended if you LAN!
