Spec me an AV cabinet thing
28 Sep 2008
Britain
Hi guys,
I'm abooot to start building my "floating wall" for my 46" Panny G10 :D
In front of the wall I want to put some AV units to stick my HTPC, AV receiver, xbox and router in.
Ideally, gloss white. I've looked at the Ikea Besta Jagra units and I think if all else fails I'll have to go for these. thing is, they are 60cm deep which is a bit much for me if I'm honest. 45cm to 50cm is ideal. Also, I'm not fussed if all the stuff is hidden behind drop down doors as I can IR extend although the HTPC case is SEXEH! ;)
Needs to be 2.4m wide (or 2x1.2 would be just as nice) and around 40 to 50cm high as I guess it would be totally ideal to have one with a drawer section to use for storage too.
Ta
I know it's not what you asked but would you consider building a compartment into your floating wall for all of AV units? I've nearly finished mine and built a compartment into the wall.
