- 30 Nov 2011
I'm not in the UK but looking at getting a new AVR, I want atmos to run 5.1.4 so looking at 7.2 receivers mainly and also want 4k120 as an option
my options in my price range are basically;
Denon X2700H, X3700H (is only about £60 more for the 3700)
Marantz NR1711
Yamaha V6A or A2A
Looking at reviews of all of the above, the denon is good looks good for movies but people are saying the soundstage for music is very limited, the marantz is only 50w per channel where as the yamaha and denon are both around 100w. I also gather that I will need to check the V6A firmware before buying as the earlier manufactured ones don't support 4K120 but the later firmware updateable ones do. I want it primarily for movies obviously, but I also plan on using it to play music, I was pretty much dead set on getting the Denon but then checking a couple of reviews and they say its not good for music as the soundstage is limited but then that doesn't exactly sound great for movies either.
What says OCUK?
Marantz NR1711
Yamaha V6A or A2A
What says OCUK?
