Spec me an electric razor/trimmer/face tidier
18 Jun 2004
Darlington//Sheffield
Hi all
As title really im after an electric razor, beard trimmer etc etc to stop myself looking like a tramp.
Anyone got any suggestions advice tips hints etc etc
Many thanks
My suggestion is to go to the shops and plump for one you think looks good and suits your budget.
Crazy, I know.
Crazy, I know.
Was planning on doing that this afternoon just though as ive never owned one before someone might have some suggestions or tell me what to avoid and whats been good for them
I do not have a full blown beard but do prefer to have a bit of facial hair, which is why i think it might be easier to keep it in check with an electric system rather than a conventional razor
Gillette mach 3 Turbo. Best disposible cartridge razor out in my opinion.
Electric ones leave you with a George Micheal style stubble unless you have bumfluff.
People might advise to get a DE Safety razor as they are uber cheap to run but take twice as long to get a shave that is no better than the Mach 3. I have tried both...
