Truecrypt, only an idiot would buy one of those encrypted pendrives when truecrypt does a much better job for free.
But it relies on the user actually using it properly.
Excellent piece of software.1. Buy normal usb flash drive
2. Use Truecrypt
It depends what you are wanting to do, do you have control of the different computers you are going to be using to install stuff on, if so the above will do the job
Nope.Do you need truecrypt installed on any computer that you put your USB drive in?
Guys can someone please tell me what benefit you would have using an encrypted usb key over a normal one? Is it for people only using the device on a designated PC i.e if you stole the key you would not be able to use it anywhere else?
As on my work PC I have a key I use which is always attached to the unit and store all my backups on it (mainly incase of HDD failure rather then security), what benifit would I see getting one of these 'Iron Keys'?
Thanks in advance,
Rich
