Spec me an entry level DSLR. (for my web business)
30 Dec 2003
So I am finally settled in the USA (long story) and I have got my Social Security Number through so now I can work.
Now to the need of a camera.
I am setting up my own webdesign business and my first client is a small professional business. I want to be able to use my own images for my websites, in turn I can charge more ect.
I used a D7000 in aus for over 2 years (underwater) and I do have experience with SLR's, I am more of a creative person rather than a camera tech nut. Also my knowledge on lenses is not the best.
I am looking at getting myself a decent camera that I can use to get a decent level of finish. I would be using it for general people shots, Interaction of them in meetings, meeting clients, at work ect. (not sure what would be the best lens)
Also I have a current client that wants a whole new support page addition including a video support page, so decent video quality will be needed.
I dont really want to spend more than 800$ (that would be me super max) yet I want something that will last me and also give me some decent results.
Thanks in advance.
D7000 is still the de-facto crop DSLR really, if you have experience with one then it seems like a no brainer to me.
All DSLRs take good photos. Canon's sensor are aging relative to Sony/Pentax/Nikon but the photos are still good in absolute terms. So whatever you buy will be good enough.
Thanks for your response D.P...what would you recommend regarding lens?
Depends a lot on what you want to do shoot.
The 18-105mm kit lens is very sharp and has a useful focal range so I would get that for starters.
For the people shots, one of the f/1.8 primes are good, the Nikon 35mm f/1.8 is the obvious choice, but the 50mm f/1.8 works well for single person/head+shoulders. For larger groups you will want wider than 35mm but the 18-105 is good for those situations since you will need a larger DoF and smaller aperture anyway (larger f-number).
I would go to Best buy and try out some of the cameras before buying. The Canon 7D is the main competitor to the Nikon D7000.
If you have a tighter budget then the D5100 has the same sensor as the D7000.
a budget option on the Canon side would be a Canon 400D 2nd hand. Canon haven't moved their sensor technology since the 400D so you basically get the top of the line Canon CROP sensor in a very cheap body. Don't know about video in the older cameras though.
Okay thanks guys. The tree company have the (Canon EOS Rebel T3i 18 MP CMOS Digital SLR Camera and DIGIC 4 Imaging with EF-S 18-55mm f/3.5-5.6 IS Lens) for $599 which to me seems good, then I would have the option of expanding later. For $780 you can get the (EF-S 18-135mm f/3.5-5.6 IS Standard Zoom Lens instead) I am sorry for been such an amateur when it comes to lens configuration.
The T4i (Canon EOS Rebel T4i 18.0 MP CMOS Digital SLR with 18-55mm EF-S IS II Lens) seems about $40/$50 more. Guess I need to do some more reading.
My 450D doesn't do video. The 550D does.
