spec me an entry level DSLR
Nikon D3000 is a nice DSLR for just under your budget but it is Nikon's poorest camera.
The Nikon D40 is older with less pixels than the newer models but it is a better camera than the D3000 and cheaper!
30D
Tamron 17-50mm
Probably be closer to £450 but well worth it.
If you can't stretch that far then...
30D
18-55
...will do a decent job too.
Go round the camera shops and try some kit. It's generally not the case that there are good and bad dSLRs. It's more about weighing up the differences.
This.
Obviously Canon and Nikon will have the biggest range of lenses and accessories available.
