Spec me an ev cable type 2 to 3 pin
  • Thread starter Thread starter 233
  • Start date Start date
233
233
21 Nov 2004
Wishaw
Looking for recommendations that won’t burn my house down so something ideally decent and branded hence not buying the first cheap one I find on Amazon or eBay
First phev so no idea who is and isn’t well regarded
For a transit phev that can charge at a max of 16amps plugging into a 3 pin domestic plug
Granny chargers are limited to 8 or 10A due to them being a continuous load.. That is all you will get out of a normal 3 pin socket.
What you want is a 16A or even 32A commando socket to type 2 and get a proper commando socket fitted responsibly at home.
Watching this one with interest as I'll most likely be needing one myself in a couple of weeks.
Looks like you can pay between £79 at Amazon to £250+ at a dedicated EV supplier.
The Transit PHEVs only have a fairly tiny battery anyway, it'll probably charge in 5 or 6 hours off a 2.3kW charger, not sure it'd be worth bothering with a commando socket install just to reduce that to 2 or 3 hours.
Plus a standard 3pin might be more useful for nabbing at bit of charge at work through the window or something :p
I bought the Masterplug one from Screwfix. It has been perfect for 2+years. I figured better than a no-name that might burn the house down although I am under no illusions it's probably a rebadged China special.
Cheers for that
My company so I pay the leccy bills
Old man’s a spark so not a hassle to change the plug
Cheers for that
If your old man is a spark just get a proper EV charger. You can get a PodPoint Pro from eBay for like 300 quid.
I'd go this route if you can get the job done properly without having to pay a fortune.
I'd prefer to get a type 2 7kWh jobbie even though I'll only have a 13kWh battery to charge. Problem is I'll need a new garage consumer unit as a minimum and most likely a beefier supply cable to the garage and I'll never see that cash back.
Seeing as I've massively compromised on the car I'll be driving to whittle down that BIK I don't want to start eating into that cash :p
