spec me an eyefinity setup please! :D (3 monitors)
22 Jun 2005
hey guys, so i am upgrading and eyefinity has caught my eye! but was just wondering how much it would cost for it!
so if you could spec me the cheapest and best 3 1920x1080 monitors i can get!
max around 400-500 but the cheaper the better! and of course the biggest possible!
regards!
If your happy to go second hand, you wouldn't go far wrong with buying a couple of second hand Dell 2407's and then you can run at 1920*1200 instead of 1920*1080.
I run three of them and I'm extremely happy with them.
Taff
I bought 3 Dell P2210H 21.5" and I love them to bits. They have a display port connection as standard. 3 Year and no dead pixels guarantee. Comes in at around £530 but also has the advantage of not needing an expensive active DP to DVI adaptor.
