- 30 Apr 2009
Right you scabs,
in my attempts to get a new workstation at work [I'm currently working with a pair of XW8200 machines with two Nocona [90nm netburst based] 3.6ghz processors each, and 4gb RAM which are basically space heaters with the ability to run an OS as a side benefit....] I'm looking at prebuilds from Dell and HP, but I'mn considering a self build as well, as it will be my own workstation, not a hot desk, etc.
As I alluded to elsewhere, I'm ordering comms cabs for a new server room, and the plan is to back up the important parts of the XW8200s, shove four terabyte SATA drives in them with proper XOR powered RAID cards, and let OpenFiler [google it, it's great] Linux based NAS servers look after them as iSCSI stores for VMs.
So obviously I need a replacement machine, or two.
The general plan is to get a rack server to run the VMs and have a single box under my desk that will primarily run *nix as my dev/day to day machine.
So given, say, £1500-2000 [the price of a reasonable spec, single drive, single CPU Nehalem based workstation], what can the OCUK crowd suggest to me as a good spec for a self-build machine?
Disk storage can be left to one drive at the moment as I have a small NAS I can use, drive speed unimportant but should be as stable as possible in all respects.
Ideally will have a chunky GPU [workstation class not important - don't fret about whether it's a Quadro or a 260GTX] for future GPGPU stuff should that be useful.
Machine will be used for running level two hypervisers [IE virtualbox as opposed to VMware ESX], application compiling, web development, video editing, and wathcing high def p*rn, er, I mean, monitoring my servers.
So, go wild. If you think there is something I need that isn't on OCUK [IE quad port LAN adapters] then just tell me the model name, and ballpark price, I can google it.
This is still pie in the sky at the moment [probably not best to float this after being off sick for a week then turning up at 2pm on my first day back...] but it's be nice to have some specs and numbers to throw at the beancounting classes should I need to.
So Core i7, 6gb RAM minimum, single SATA disk, decent connectivity, good GPU, and as quiet and cool as possible as it'll be in the office.
GO!!
GO!!
], and built like the proverbial brick outhouse.
my home machine outperforms both XW8200s put together!] given that the Nehelams will out out 70 at sstock speeds*. And I am aware of that moniter. I ordered one for a mate in the office, and I covet it, dearly...I need something bigger and with more pixels for my desk. Justification being monitoring multiple virtual machines in VMWare Infrastructure
