- 27 Dec 2005
- Bristol
I'm looking for a cheapish 720p IP camera. Only thing I need is for it to be viewable via a browser on the same network (local IP address is fine), and it can also connect via WiFi or Ethernet, doesn't really matter.
Don't need it to record in any way, be it local or cloud.
I would just get two normal USB webcams but the computer will be in a different room, albeit on the same local network, so this won't be feasible.
Any recommendations?
they have a whole host of cheap i.p camera's i have used a number from that website and all good quality and have been going years. i have a 720p one and a 1080p and would recommend a 1080p tbh the difference is quite a bit. i have always used onviv ones.
