Spec me an LCD Wall Mount Bracket..
11 Jun 2004
Middlesex, London
Hi all,
I need to buy a decent LCD Wall Mount thingy for my 40" Sammy.
... But I don't know what I should be looking for?
There hundreds on flea-bay... Can anybody please help or advise?
Thanks
yep :)
just got one yesterday for my 40" F86 im gonna get...
this one has a great range of motion, including Vertical and horizontal planes of movement.
the best thing though is its only 88 with the vesa adapter and next day delivery, takes up to 36KGs, and the F86 is 20KGs without the stand ;)
linky
remember you need to by the 200*200 VESA adapater seperately, but even then its miles cheaper then anything else.
I've just bought 3 brackets, all for different installations,
It really does depend on what you want, if you want it as flush as possible, or the ability to angle in one or more axes etc..
I found that the online jungle river store had a massive amount for very very cheap prices, as does the bay, nothing to recommend as such, they all 'work' you just need to assess what you need from it..
