Zebralight SC600,had one for a few months and i love it:
http://www.flashaholics.co.uk/zebralight/zebralight-sc600.html
cpf code gives you 8% off.
How did you find your H7?
I finally have this torch, my god! It makes my C8 look like it's stuck on low power mode! Can't wait to try this thing in the dark.
It seems to be a dark green military kind of colour though, where the others look black.
Thanks for the recommendation, I'm very impressed.![]()
Great. Used it on a job the other night. Made life a lot easier. Good Luminosity and adjustable up and down as needed so i'm not shining it in peoples faces...
I've spent ages trying to decide on a torch, and I changed my mind far too often, so I decided last week to just grab a cheap sub £30 2x rcr123a torch whilst I decide whether I really want to spend £60 on a good one. Wanted it before last weekend's night shifts, so bought one of these from Flashaholics:
http://www.flashaholics.co.uk/lumintop/lumintop-p2c.html
I have to say, I'm pleasantly surprised, it's really good! I already had a charger and some batteries, so i'm running it on 2x 3.7v RCRs and its really bright! Build quality isn't amazing, the LED is slightly off centre, and the clip is a little bit easy to remove, and it's lacking momentary on from the switch, but it slips into the molle webbing on my tac vest perfectly, and the light is perfect. It's got a decent throw with a good amount of flood too.
I turned up at a job the other night in a dark garden, and was able to light up the scene perfectly, the paramedic there was impressed, he was struggling with his issue maglite!
I honestly cannot believe this thread manages to stay on the front page after all this time
Really over a torch ?.
Something's never cease to amaze me.
I already have a Quark AA 2 turbo but for some reason find myself drawn to buying a NiteCore-EA4
Review of it here
http://www.candlepowerforums.com/vb...NEER-(cool-white)-review&highlight=ea4+review
Why would I need this? either way, I have just bought one for £42![]()
Led lanterns. Any good? Thinking about a wind up one for the power cut box.
