Glass update seems worth it to me.
I have it on 6 and 4 d cells mags and also on a mini maglite. All with Terralux bulb upgrades.
It's more than worth it. Me, If I can only upgrade the led on my maglite solitaire, I will.![]()
So which LED upgrade would you recommend I go for? I don't really know the difference between the two I mentioned in my last post.
I've got a pair of Ultrafire WF-501b torches for my bike but they keep switching modes when I go over bumps, is there anyway to mod them to just be on/off? I have no use for the other modes.
Might be due to the battery moving about and losing contact with the spring. You could try lining the battery tube with paper to make the battery a better fit. Also adding a little button magnet to make the battery longer could work.
Mark A, mrk - How long did it take for your TN31 to arrive from China and did you escape any import duties?
Just ordered the new TN30 at a promotional price that uses the new Cree XM-L2 U2.
- Max 1376 lumen output
- Max beam distance: 840 meters
- Peak beam intensity: 90000cd
