There needs to be more regulation I think, all these torches on ebay claiming massive lumen output when they probably provide 10% of that figure, absolute fraud.
Surely If the lumen isn't anywhere near the claimed figure, its fake?
Bought this for £2.80 delivered from Hong Kong/Chinaland from a seller on Amazon - http://www.amazon.co.uk/exec/obidos/ASIN/B007B86KLC/ref=ox_ya_os_product
The one that arrived was the actual Cree one not the cheapo one listed for £2.80. Didn't get stung for customs either.![]()
Nice, how long did yours take to come? Mine is comming from Hong Kong and was dispatched late last night? Ive ordered this........ http://www.amazon.co.uk/ULTRAFIRE-W...8&qid=1391352680&sr=8-2&keywords=ultrafire+c8. I wanted one with a large head, and the C8 fits the bill nicely.
What do you mean by actual CREE one? They don't make torches do they? Mine says CREE on it but as far as I know that just Ultrafire putting the logo on it
The torches of that style are all just Nitecore Extreme knock offs I think, so whatever you got, unless it was a Nitecore was the cheap Chinese knock off.
Still good though, well impressed with mine still
Ive just come across this one http://www.trustfire.com/en/flashlight-tr-3t6-3x-cree-xm-l-t6-3800-lumens-5-modes.html
What do you think? on amazon its £20, its quite big and stupidly bright
Ive had similar, I dont recommend 3x xml T6 especially without a set of very nice batteries
The CREE is the lcd bulb type that the ultrafire's use.
thinking of buying this, as i need a compact bright light! any thoughts?
http://www.flashaholics.co.uk/nitecore/nitecore-p12.html
I'm sure it's a nice light but it does somewhat strain the definition of the word "compact" to me. it's 14cm long and an inch wide, so it's not exactly tiny.
What do you plan on using it for?
