Got my knockoff Solarforce torch today. The MC-E dropin is absolute rubbish. The centre spot is a doughnut, the beam is bright yellow and its not very bright at all. Removed it straight away and put my Manafont XML dropin into it.
Build quality seems decent enough. The threads look very similar to the Solarforce and the head is interchangeable with the real Solarforce, but the tail cap isn't. The rubber seals don't seem as tight and i'd be worried about using an expensive dropin with this tbh. Maybe they just need a bit of silicone grease. I might try it under water with the crappy MC-E dropin later
