Not sure if it's the cheapest but.
http://www.ebay.co.uk/itm/280751589397?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2648
I have that very one, its got a very good beam on it, for what i need it for anyway.
Unless your requirements have changed there's nothing available that suits you.
this is the closest you'll get without spending more than £100; http://www.flashaholics.co.uk/olight/olight-i3-eos.html
Same thing but in Stainless Steel; http://www.flashaholics.co.uk/olight/itp-a3-eos-stainless-steel.html
because it would be hand and custom made![]()
I honestly think i could make something that would work and not cost a lot, im thinking a powerful small battery of some sort and an xml in a bit of copper pipe, should do the job.![]()
The rolleyes wasn't necessary, no torch is worth that,
i wasn't trying to be funny, im pretty sure i actually could make something half decent myself, it wouldn't look as fancy but it would do the job, there's really not a lot that goes into these things, you can cannibalize something off the shelf and change it however you like.
Man that's pretty![]()
I disagree.
Will you post back here when you've made it - I for one would love to see it. I've a lot of respect for those that can make things themselves from scratch.
Any idea what LED you'll use? WIll you buy a star or mount it yourself? How about the driver? Fully regulated or tapering? Multi or single mode? What kind of switch are you thinking of? What about the reflector and lens?
Back to your original question - this is shorter than an AAA battery and only a few mm wider and puts out 180lm.
It is so bright i think it is quite dangerous should you shine it onto the road.
Will really have to watch where and who I point it at I think.
http://www.ebay.co.uk/itm/UltraFire...ing_LightsLanternsTorches&hash=item4cfb5b4ee2
http://www.ebay.co.uk/itm/UltraFire...ing_LightsLanternsTorches&hash=item415bb64e5f
Do any of the cheaper makes not do any powerful AA/AAA torches? Obviously you cant trust what it states in the ad, but are any of them any good?
